SSD Upgrade help
Go to solution Solved by VioDuskar,
format HDD it will wipe the HDD
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/408508-ssd-upgrade-help/#findComment-5502756
So I recently added to my build an SSD. I cloned it from my HDD and now I'm wondering what's the procedure to erasing my HDD.
Do I just select all and delete it or install a software?
I do also plan on using the HDD to hold games and other stuff.
follow your thread. also, your font color offends me.
https://linustechtips.com/topic/408508-ssd-upgrade-help/#findComment-5502759
Uhh what font color?
i use a dark theme and your font and the font highlight is white, because both are white it's hard to read.
https://linustechtips.com/topic/408508-ssd-upgrade-help/#findComment-5502777
