Resetting(?) Old Hard Drive
Go to solution Solved by dudeskee1325,
Ok, I deleted the partitions, but how do I allocate the unused space to the main drive?
EDIT: lots of clicking was the fix! Thanks man!
I pulled my hard drive out of my old laptop to use as an external one for media, but I see that it shows up as 3 separate hard drives. I've tried wiping it with ccleaner and reformatting it/them but they still show up as 3 separate drives. What can I do to make it show up as just one?
https://linustechtips.com/topic/408397-resetting-old-hard-drive/
go into disk management and delete partitions.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/408397-resetting-old-hard-drive/#findComment-5501431
