USB to Ethernet adapters
Hey guys,
Just wondering, does anybody know if you lose much internet speed via a USB to Ethernet adapter?
I was curious as I wonder if anybody has tested just running an ethernet cable straight into say a laptop and then tried again going via the USB with an adapter and what the difference was.
Cheers
https://linustechtips.com/topic/407911-usb-to-ethernet-adapters/
I have used them before. 10/100BASE-T adapters will work just fine on USB2.0.
1000BASE-T will technically work on USB2.0, but you will be limited by the speed of the USB port. USB3.0 and above can handle a gigabit connection no problem
~Judah
https://linustechtips.com/topic/407911-usb-to-ethernet-adapters/#findComment-5495788
If using USB3 it should be around 90% as fast but it really depends on what NIC is in the adapter.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/407911-usb-to-ethernet-adapters/#findComment-5495795
I use a USB-ethernet adapter on my macbook, and speeds really aren't affected that much, but the latency is.
Like, 1ms or so or what?
Cheers guys, the one I got is a USB 3.0 to Ethernet adapter, should do the trick it seems!
What did you get? Got a link?
https://linustechtips.com/topic/407911-usb-to-ethernet-adapters/#findComment-5503551
