I have a 970 and I'm getting a new psu but in the mean time will it run okay on 1 6+2 connector if I dont play games on it. My current psu is a aero cool integrator I figured it will only have a low powerdraw I'd it's not using anything me than 50%
https://linustechtips.com/topic/407417-i-need-some-advice/
if you use only one eight pin connector then the card doesn't even power correctly on with your system and causes a bunch of problems.
So no you can't. it has the extra power delivery for a reason
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/407417-i-need-some-advice/#findComment-5490128
Does your 970 need more than that? Mine only uses a 6+2, so I don't see why you should have an issue.
CPU: AMD 7800X3D Motherboard: NZXT B650E RAM: 32GB 5600 30-CL Corsair Vengeance DDR5 GPU: MSI Gaming X Trio RTX 2070 PSU: Corsair RM850i Monitor: Samsung 27" 4K thing Cooling:Noctua Chromax Black NH-D15: Case: NZXT H510 Black
https://linustechtips.com/topic/407417-i-need-some-advice/#findComment-5490130
I do know it's possible to run graphics cards with a 6-pin connector in an 8-pin socket, because it'll automatically detect that, but I'm not sure if plugging in just a single power cable is going to have the same effect. Given the available wattage overhead on 8-pin cables over the official maximum it's unlikely that you'll actually damage your components, but I'd say it's a very real possibility that it will simply refuse to run.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/407417-i-need-some-advice/#findComment-5490133
https://linustechtips.com/topic/407417-i-need-some-advice/#findComment-5490180
