So let me start from the beginning, a while ago I bought a hp pavillion desktop and recently I upgraded, but I have stayed with the same HDD throughout the upgrade so now windows 7 wont boot on it because of the upgrade, I have made multiple posts and my decision is to buy windows 8.1 from g2a and install it, but the only other pc I have is a old celetron vista pc of which I am posting this from, and I was going to get the iso for windows 8 from the iso creator but the creator does not work on windows vista :( can someone please help.
https://linustechtips.com/topic/407272-help/
I can't understand, did you update your os to windows 8.1?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/407272-help/#findComment-5488143
The OEM version that comes with the pc should not work on all hardware, instead it should only work on the first HDD that it came with. If you bought a windows 8 license key, I recommend using Rufus to create a bootable USB to install the iso onto.
amnerd  B) Linux enthusiast.
  • CPU: Intel i5 4690k @3.5ghz  Motherboard: MSI U3 Plus Z97 GPU: Radeon R9 270x 2gb OC HDD: WD Green 3tb SDDs: Samsung 120gb, Kingston V300 120gb Case: Fractal Design Define R5 PSU: Corsair V650 Fans: Corsair AF14 x4 CPU cooler: Hyper 212 EVO (Upgrading soon)
https://linustechtips.com/topic/407272-help/#findComment-5488174
the issue is that I cant get an iso, I need a download for one.
https://linustechtips.com/topic/407272-help/#findComment-5488204
So do you have the windows product key?
https://linustechtips.com/topic/407272-help/#findComment-5488225
yes
Alright, well then go here and get the iso, then enter your product key during setup
http://windows.microsoft.com/en-GB/windows-8/create-reset-refresh-media
https://linustechtips.com/topic/407272-help/#findComment-5488297
Is there no other way to do it?
Not really, you need to get an iso, which you can burn to a usb. That is the only way if you have the product key.
https://linustechtips.com/topic/407272-help/#findComment-5488397
resaying it is it legal for you to send me a download for one, I have a 64 bit regular version of windows 8
What do you mean?
https://linustechtips.com/topic/407272-help/#findComment-5488725
poke
Oohh I see what you mean. The download will create an installer but only that can be accessed by your key.
https://linustechtips.com/topic/407272-help/#findComment-5489156
You have to do it yourself, because the USB drive that you install it on is specific to your pc. You need to do it, it's easy.
https://linustechtips.com/topic/407272-help/#findComment-5493040
