System 2
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/407105-which-system/#findComment-5485915
System 1, no question
Wait really?
https://linustechtips.com/topic/407105-which-system/#findComment-5485918
Nevermind, I had a different build open xD, System 1 is better
https://linustechtips.com/topic/407105-which-system/#findComment-5485925
Wait really?
That APU in system 2 is... bad....
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
https://linustechtips.com/topic/407105-which-system/#findComment-5485929
system 1, but instead of a 960 get a 280x, you'll get  better performance for around the sameprice
Correct
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
https://linustechtips.com/topic/407105-which-system/#findComment-5486092
i have two system builds which one is best for gaming
system 1
http://uk.pcpartpicker.com/p/pgKmZL
system 2
http://uk.pcpartpicker.com/p/LrHM7P
Neither... get this and add a cooler later.. Can also change out to an AMD card for better bang for buck. Drop to an i5 4460 to bring the price into check and still beat the AMD.
get a smaller PSU if you'll never go SLI / CF, 550W is more than enough... xfx over corsair.. EVGA B2 GS or G2 are good options too as are superflower.
http://uk.pcpartpicker.com/p/ckMsQ7
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/407105-which-system/#findComment-5486136
