Fan Config Help
Go to solution Solved by xnoobftw,
Meh since your 970s are the blower styles it is perfectly fine :)
So I'm not sure about my fan config in my case. I'm using a Corsair 450D with 2 intake fans on the front and one exhaust in the back. I'm also using a Nepton 240m for CPU cooling pooling air into the case and I'm running 2 blower 970s. Should the fans on the rad exhaust air? Anything else wrong with my config?
https://linustechtips.com/topic/407040-fan-config-help/
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/407040-fan-config-help/#findComment-5485148
