Need help, is it good?
Go to solution Solved by MockingBurns,
Idk what's up with the face, ignore it.
I need help with building my first pc, I was wounding if someone would say if; a) the parts would actually work together, and b) would make an okay gaming pc. I've been looking at an evga GeForce gt 610 graphics card, a Corsair Builder Series CX 430 Watt ATX/EPS 80 power supply, two HyperX FURY Series 8GB ram, a AMD FX4300 Black Edition 4 Core processor, a Asus M5A78L-M/USB3 Motherboard, a AVP Storm P27 Midi Mesh case, WD 1TB 3.5 inch Internal Hard Drive - Caviar Blue hard drive. Good or no? I'm on a budget so I have to go cheep.
https://linustechtips.com/topic/406734-need-help-is-it-good/
The parts should work just fine but the system seems unbalanced.
We could help suggest some alternatives if tell us what the system is being used for, where you're shopping/located, and budget.
https://linustechtips.com/topic/406734-need-help-is-it-good/#findComment-5481269
Gaming primarily, and about £600 to £700, and shopping online or close to me.
https://linustechtips.com/topic/406734-need-help-is-it-good/#findComment-5481294
That seems like quite a healthy budget and doesn't seem to match your intital parts list. Is that just for the tower?
Also, I've been given the gt 610, so I don't really want to buy a new one if I can manage.
The GT 610 is pretty bad for any gaming that isn't very light like The Sims.
https://linustechtips.com/topic/406734-need-help-is-it-good/#findComment-5481311
Location as in US, Canada, Europe?
I don't think the OP is using british pounds in the US or Canada.
https://linustechtips.com/topic/406734-need-help-is-it-good/#findComment-5481320
I have to get the tv and everything like that with the cash too
https://linustechtips.com/topic/406734-need-help-is-it-good/#findComment-5481323
What's 'everything like that'? It would be important to mention if it's being included in the budget.
Why a TV instead of a traditional monitor?
https://linustechtips.com/topic/406734-need-help-is-it-good/#findComment-5481355
I mean the keyboard, mouse, screen (called tv out of habit)
Is a copy of Windows needed?
https://linustechtips.com/topic/406734-need-help-is-it-good/#findComment-5481377
No, I have access to Windows 7
I'd suggest something like this instead: http://uk.pcpartpicker.com/p/wv2d23
https://linustechtips.com/topic/406734-need-help-is-it-good/#findComment-5481443
