Nexus 5 Display !?!?!?!?
Go to solution Solved by Stuff_,
Damn, looks like something bad happened.
I would turn it off, and leave it off for a few hours and see if it still looks like that.
If it does, it's likely ruined. Not sure how or why, but a replacement display assembly isn't that expensive. They are like $50.
It was fine a couple hours ago, left it on my wireless charger while I was in the shower.
Now the color around the edges is all messed up.
EDIT: Seems like the backlight flickers when the brightness is turned up all the way
[spoiler=»--((¯`·._.·¤~●oO му яιg Oo●~¤·._.·´¯))--«] Case: Corsair 600T White       CPU: Core i7 3930k @ 4.3GHz                     SSD: Crucial M500 480GB
MB:    Asus P9X79 LE         GPU: Nvidia GTX 780 Reference             HDD: WD Caviar Green 3TB
PSU:   Seasonic X-1050      RAM: G.Skill Trident X 32GB @ 2.4GHz   ☃ There are 10 types of people in this world. Those who understand binary and those who don't.
https://linustechtips.com/topic/406516-nexus-5-display/
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5478574
Try to claim a replacement under your warranty. Call your mobile carrier.
amnerd  B) Linux enthusiast.
  • CPU: Intel i5 4690k @3.5ghz  Motherboard: MSI U3 Plus Z97 GPU: Radeon R9 270x 2gb OC HDD: WD Green 3tb SDDs: Samsung 120gb, Kingston V300 120gb Case: Fractal Design Define R5 PSU: Corsair V650 Fans: Corsair AF14 x4 CPU cooler: Hyper 212 EVO (Upgrading soon)
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5478597
Was it hot to the touch when you came back to it?
My Build: Phoenix
Processor: Intel i7 4770k, Motherboard: Asus Z97-P RAM: Corsair Dominator Platinum 16GB GPU: MSI GTX 1050TI OC Case: Corsair ICUE 4000X, Storage: Samsung 840 EVO 120GB + 500GB + 2TB HDD PSU: Corsair RM750, Cooling: Corsair H100i Capellix,
        If you want to talk to me or give me an answer, please tag me otherwise you'll be talking to thin air ❤️
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5478631
Not very, about the same after wireless charging
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5478657
this looks to be a thermal issue and wireless chargers do get hot. I would send it back.
I bought it November 2013 from the google play store.
How do I send it back?
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5478677
Email Google about the issue. Tell them that you were using the phone on a wireless charger and then this happened. They will probably send you another email for extra information and stuff, and then probably give you a prepaid shipping label to send it to them.
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5478691
Okay, thanks.
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5478713
Left it off for a day, it is perfectly fine now..
Not sure what happened though.
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5488656
There is a slight chance that the LCD driver chip had an issue with the power output by the wireless charger. I have usually seen this as a thermal issue on thr LCD though. I charge my N5 and N7 every night on a wireless charger. But it is a half decent one from Amazon, not a derpy one from China. Sometimes China will omit components on a board as long as it still functions at all just to save cost, and sometimes devices cannot handle it (out of spec voltages, electrically noisy signals, ect). My 16$ one from amazon is a much better design than my brother's 3$ one from China. Mine charges faster and doesn't even get warm.
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5492187
That's strange & I use the wireless charger from google. I think it was ~$50
https://linustechtips.com/topic/406516-nexus-5-display/#findComment-5539171
