Need help on picking a case
Solved by x Relentless Xx,
I'm looking for a Mid tower case with good air flow for under 60$, There's
3 cases i have in mind Cooler master n200, Fractal core 1100 and the BitFenix comrade. I don't really care about anything flashy just a case this has good air flow that can get the job done, Thanks for the help
bump up your budget by$10 and get the NZXT S340. But, i will give you the same advice i give everyone else when picking a case. Pick a case that defines you and your personality
Also, follow your own topic so you get a notification
