PC Build for under 2000
Go to solution Solved by Jacktastic-Mofo,
http://pcpartpicker.com/p/gRYDsY
Don't know if black / red is your thing but this is kinda a boss- great for gaming, streaming, rendering, and all around multi tasking!
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/406140-pc-build-for-under-2000/#findComment-5473258
Thanks seems great
I made sure the monitors were great, they're 1080p, 60hz refresh rate, and IPS! Once you game on IPS you can't go back to TN or anything else! Also IPS is pretty important for a surround setup because the two side monitors are gonna be at odd angles. Also make sure to post pictures once you build it!
https://linustechtips.com/topic/406140-pc-build-for-under-2000/#findComment-5473325
Ultimate gaming rig with a 980ti destined for its 1ms 144hz g-sync moniter.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($199.99 @ Micro Center)
CPU Cooler: be quiet! Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler ($74.90 @ Newegg)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard ($104.98 @ OutletPC)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory ($42.99 @ Newegg)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive ($59.99 @ Mac Mall)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.99 @ Best Buy)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Video Card ($648.95 @ B&H)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: Antec TruePower Classic 750W 80+ Gold Certified ATX Power Supply ($54.99 @ Newegg)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor ($129.99 @ Newegg)
Monitor: AOC G2460PG 144Hz 24.0" Monitor ($399.99 @ Newegg)
Total: $1994.74
Generated by PCPartPicker 2015-07-13 00:01 EDT-0400
https://linustechtips.com/topic/406140-pc-build-for-under-2000/#findComment-5473613
