Okay few days ago i had on my Dxotry codec called openencodevfw https://github.com/jackun/openencodevfw
and i got a suggestion from someone to try out MSI afterburner he told me that it's better so i did that...
MSI afterburner was eating a lot of performance, so i decided to go back to Dxtory and when i entered Dxtory my codec disappeared
http://i.imgur.com/Ny00DgQ.png
I tired to reinstall it, didn't work.. I deleted dxtory everything and installed it again and still i couldn't install (Well i did but it's just wasn't there) my Sweet openencodevfw....
So what would you guys recommend?
https://linustechtips.com/topic/405815-dxtory-big-problem-please-help/
most people now adays use OBS with either nvenc or amd vce
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
Can't you just use OpenEncodeVFW with Msi Afterburner? Similar performance hit anyway.
I don't know how to use OBS, i don't know how to install VCE on it.. every time when i record something video gets cut from every side....
Could you help me out do you have skype?
its really easy
do you have OBS?...the VCE edition?
I don't know how :(
Are you using Catalyst 15.7 btw?
I downloaded first one..
EDIT: what now?
starts at about 3:10
obviously you wanna use the newest version
https://obsproject.com/forum/threads/obs-branch-with-amd-vce-support.13996/page-99
this page has some other people saying what settings to use
yeah
AMD APP is missing in Catalyst 15.7, you might want to try finding AMD AVT  package in older Catalyst and install them.
280X
ya it will work fine then
might have to play with the setting a little bit tho
I would probably use a bitrate of like 8000-9000 for 1080p
see how that looks first
WAT?! I don't know how to do that shit OMG!
Can you help me out please PLEASEE :)
Nvm i just tried, not working.
