Hi Peeps
I am looking for a case  that isn't too pricey and has the follwing,
Has some sort of cable management
Is sturdy and not flimsy
Has 3 x 3.5 Drives
Can take a m-ATX form factor MoBo
Has enough room for a cooler master hyper 212 evo heatsink
I'm just looking for a plain sort of case as I dont need flashing lights as it is not at all for gaming.
Many Thanks for any help given
Cheers
https://linustechtips.com/topic/405756-new-case-help/
The spec 02 is OK it has all of what you are looking for
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
https://linustechtips.com/topic/405756-new-case-help/#findComment-5468416
Any 5 1/4 inch drive bays needed? (For optical drives).
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/405756-new-case-help/#findComment-5468438
Even if it was for gaming, you wouldn't "need" flashing lights...
Any Fractal Design case fits your criteria.
Except the Define S, which doesn't have room for an optical drive. Other than that, they fit perfectly.
https://linustechtips.com/topic/405756-new-case-help/#findComment-5468508
So micro ATX mobo? How about the Fractal design arc mini R2, corsair 350D (maybe too expensive), phanteks enthoo pro M (not out just yet I don't think, but looks like it'll be around £60)
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/405756-new-case-help/#findComment-5468600
OK then bells and whistles, lol
One more thing I only have a USB2 MoBo Asus PQ5PL-AM, sorry about that guys.
xx
P.S if anyone can point me in the right direction of 8GB of RAM 2x4 that wont cost the earth that would be very handy.
https://linustechtips.com/topic/405756-new-case-help/#findComment-5469574
xx
Right now, the G.Skill Ripjaw X Series is pretty cheap. It's about $50 for DDR3-1866.
It's a decent price imo and it has pretty good reviews.
Also, Corsair has the Corsair Vengeance for slightly under $50 if you're into that.
Don't be fooled by the bottom line of my sig, that is just for my travels.
So you're telling me that Gaben is no God? Enough of your foolishness.
My hardware you ask? I'm using a Dell Inspiron 3217 Notebook... With an LG 25UM57.
https://linustechtips.com/topic/405756-new-case-help/#findComment-5470069
Would you know of any links?
Also still looking for a case with USB 2.0
https://linustechtips.com/topic/405756-new-case-help/#findComment-5477372
