If you can spare no expense, Noctua. They are amazing. I only own one, and it's a 60mm that spins at pretty high RPM, but it's literally almost completely silent while running.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/405533-case-fans-help/#findComment-5465324
I'm looking for some 120mm fans for my pc to get off some heat.
I've been looking around but there's not many good review about that.
Any recommendations from members of the best forum in the world?
depends on price and if you want 3 pin or 4 pin fans.
i personally like cougar fans, i feel they are great for the price. noise blocker e loops ,nocuta, be quite are also great fans, they can be on the pricey side though and really aren't worth the cost to most people (including myself.)
what were temps? you're looking at a 2-5c decrease in temps if you have temp problems to start with; not much of a decrease,the biggest reason to get better fans is less noise for better/same temps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553006&cm_re=cougar-_-35-553-006-_-Product < hard to beat at the price.
ps. don't forget to follow your topics :)
fan reviews http://thermalbench.com/
https://linustechtips.com/topic/405533-case-fans-help/#findComment-5465330
Why not get 140mm's?
Because not all cases can take them? I reckon that's the issue.
Personally I'd just go for some Noctua Redux 120mm fans. They're not excessively expensive but they're still very good.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/405533-case-fans-help/#findComment-5466738
Where are you shopping/located? Budget?
Specs? Are you not satisfied with your current cooling?
https://linustechtips.com/topic/405533-case-fans-help/#findComment-5466750
