Is it possible for me to overclock my 390 GPU and is it possible for me to use crossfire with another 390?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($129.98 @ OutletPC)
Memory: Mushkin Stealth 16GB (2 x 8GB) DDR3-1600 Memory  ($95.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Case: Enermax OSTROG ATX Mid Tower Case  ($43.99 @ SuperBiiz)
Optical Drive: LG GH24NSC0B DVD/CD Writer  ($16.89 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($89.99 @ NCIX US)
Total: $1140.34
Generated by PCPartPicker 2015-07-11 19:08 EDT-0400
https://linustechtips.com/topic/405388-msi-radeon-390-overclocking/
Total: $1140.34
Every card can be overclocked... they just have limits. Have you ever overclocked a gpu before?
Yes you can OC it ( try youtube for help or the forum)
and it is possible to put another 390
CPU:AMD FX-8320, RAM:Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600, GPU:MSI Radeon R9 280, Case:Cooler Master 690 III, PSU:Thermaltake Smart 650W
Storage:WD Purple 1TB, CPU Cooler:Hyper 212 EVO, Keyboard:SCI Granite, OS:win 8.1 64bit, Display:Samsung SyncMaster SA100, Mouse:CM Storm Spawn
I am trying the forum, this is my help thread haha.
So, do you have afterburner ?
It is possible, yes. MSI Afterburner is a good program to use.
You'll want to download a benchmarking software, such as Unigine Heaven or Valley so that you can test the stability of the overclock.
In general, it's a good idea to adjust the clock in small amounts (20MHz or so), then test using your benchmark software. Either crashes, artefacts or general issues mean that your overclock is unstable and needs to be reduced. You can keep adjusting the clock, then testing, then adjusting until you start seeing issues. Once you do, reduce the clock a little and test again. Once it seems to be stable, run a long benchmark to make sure it's completely stable, then you're done.
Ok thank you, has anyone successfully overclocked the 390 yet? Also will I have to adjust any voltage?
Love the look of your build :D
Depends how far you want to go with clocks. Every chip will vary, one persons experience overclocking with even the same card will be different. So, only use their experience as a basis for your OC. Don't expect to get the same results.
Ok how do I know when I should up the voltage.
if the gpu crashes in a test
edit: Ninja'd
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
I'm confused, if it crashes I thought I would just lower the clock speed.
If it crashes it means its not stable at that clock with the current voltage/power or sometimes you just get a lemon that no matter how much voltage you put into it the cards clocks won't go any higher stable.
What's the highest voltage I should overclock to?
