I see. That actually makes sense. I didn't think about it that way. Which stress testing tool are you using? I might as well just use the same.
Since I presume you're running OSX I'm not sure if you'll have access to the same tools
as me. What I did is compress/decompress files which are several gigabytes in size with
a compressor which can do parallel compression on multiple threads. But you might want
to google around a bit to see if there's something suitable for OSX.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
Or I could just find a stress testing tool. Yeah, I might do that instead :P
Desktop: i9 12900K - 64GB 6000 MHz CL36 - RTX 4090 X3 OC
Unraid server: Ryzen 3900X - 32GB 3200 MHz CL14 - Quadro P2000 - 50+ TB raw
This is not a fanboy thread. If you have something bad to say about Apple's products, don't say it in this thread, please.
When I sit around the house browsing the web, my Macbook Pro mid 2014 runs extremely hot. I've installed smcFanControl to check the temperature, and just writing this thread, I am running at 68 to 72 degrees.
I only have Chrome open, but I have a few tabs open (not more than 6). None of the tabs have anything running such as YouTube (which makes my Macbook run at over 80 degrees sometimes).
What could cause this? The fans spin up to 5000 RPM sometimes, which is loud as hell. I can barely touch the gap between the keys, as the metal is really hot.
Maybe I got a bad sample? What do you think?
My 2011 runs at 80C+ Often, but not until I open an intense program (or 40+ Chrome tabs).
You might want to dust it out, or if you got apple care, take it to an apple store and they will take care of it.
https://locate.apple.com/dk/da/
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
You talk about temps and fan speeds, but what is the CPU load like at the time?
There are some bizarre background processes and deacons in OS X that could cause this, as I have experienced Kernel Task maxing my CPU when I do certain, seemingly unrelated tasks.
To stress it, open up the task viewer, and terminal.
Put, "yes > /dev/null &" in the terminal, and repeat the command for every CPU core you have.
For example if I wanted to stress my 8 core, i would put "yes > /dev/null & yes > /dev/null & yes > /dev/null & yes > /dev/null & yes > /dev/null & yes > /dev/null & yes > /dev/null & yes > /dev/null & ".
EDIT: it's worth noting this will run forever if you let it.
To stop it, restart.
