Hello, Lately I have been noticing with my XFX Radeon 7950 that the temperatures have been getting much toastier than they have been before. During a typical Battlefield 4 game, it reaches 77*C, I worry a little because a few months ago, it was running around 60*C. I have taken the card out and cleaned out all of the dust and that has not affected anything. The Card has a pretty beefy cooler with 2 fans, and i recently installed a 200mm side panel fan blowing directly onto the card. Could it just be because the card is getting older? The card is at stock settings @ 925MHz on the core and 1250 on the memory, I would like to overclock it a little but I fear the temperatures will get way to high.
Thanks
https://linustechtips.com/topic/404109-graphics-card-temperature/
Replace that side panel fan.
If your card is using a standard setup it will vent air from the sides, and front of the card. Which means if you have air blowing in from the side it can work against the actual cooling fans on the cooler. If you can, more it under the card to pump air to the fans, or above the card, to blow air ontop of the back of the card.
Secondly, you might consider swapping the thermal compound on the card. It could be that the thermal compound on there has dried out, and thusly not performing as well.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
Don't bother changing thermal paste, that's not something that will dry out unless the card has been taken apart previously (And if you did take it apart for cleaning make sure you replaced that paste) or the cooler wasn't properly attached. Also agreeing with Atmos about the side fan, take it out, use something on the bottom if possible. What case is the system in?
Specs: Corsair 900D Chassis, Asus Sabertooth X99, Intel i7 5820k @ 4.2ghz, 32GB Corsair Vengeance 2400Mhz DDR4, MSI RTX 2080 Sea Hawk EK-X, Corsair HX1000iW PSU, WD Black SN750 500GB NVME (Boot), WD 1TB NVME (Games), WD Red 4TB HDD (General Storage).
Watercooling: D5 Pump (EK Top), 2X 480MM Swiftech Rads, Apogee HD CPU Block.
Peripherals: Razer Blackwidow Chroma Keyboard, Razer Mamba-T Edition Mouse, Corsair Viod Pro Headset, BenQ XL2420T 120Hz Monitor.
