Hey, i just got into thinking about my ram setup after watching the latest tech quickie video
if i have 2*2 GB Kingston 1333 MHz RAM will it bottleneck my 8GB 1600MHz Kingston HyperX Blu? - I have a total of 12 GB RAM with all the sticks
I'm wondering if my PC will be faster despite having 4 GB of memory less
PC Specs:
AMD Phenom II 965
Gigabyte GTX660ti OC
Gigabyte GA-MA770T-UD3 Motherboard
256 GB Plextor MP5Pro SSD
PSU: 750 Watt noname
Asus Xonar DGX sound card
Running on Windows 8
https://linustechtips.com/topic/4037-ram-help/
your memory will run at 1333MHz. Technically a bottleneck but negligible difference . Even if you buy 2 dual channel kits at 1600MHz they may not run at 1600MHz if all 4 slots are populated.
Its luck of the draw :)
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/4037-ram-help/#findComment-49407
Hey' date=' i just got into thinking about my ram setup after watching the latest tech quickie video if i have 2*2 GB Kingston 1333 MHz RAM will it bottleneck my 8GB 1600MHz Kingston HyperX Blu? - I have a total of 12 GB RAM with all the sticks I'm wondering if my PC will be faster despite having 4 GB of memory less PC Specs: AMD Phenom II 965 Gigabyte GTX660ti OC Gigabyte GA-MA770T-UD3 Motherboard 256 GB Plextor MP5Pro SSD PSU: 750 Watt noname Asus Xonar DGX sound card Running on Windows 8[/quote']
You're fine don't worry about it too much.
https://linustechtips.com/topic/4037-ram-help/#findComment-49472
I have already got all of the ram and yes it runs at the 1333 MHz' RAM speed, I was just wondering if anyone had some experience with this. but I think that I will be fine :-)
I have never personally had problems with the more sticks of ram the less stable it will be. I know sometimes it can cause problems with the overclock on a processor or the speed that the individual sticks are running at. In my opinion, I don't think the stability becomes a problem until you are trying for bleeding edge overclocks or speeds that the sticks of ram aren't really rated for.
https://linustechtips.com/topic/4037-ram-help/#findComment-49622
Yes, 1866 is faster than 1333. It depends what you're doing to if you would really notice it though.
Also if you use more than 8GB of RAM for anything the 12GB of 1333 would be the better option
https://linustechtips.com/topic/4037-ram-help/#findComment-50507
