i had a 450W UPS with a 550W pc, so the only thing affected is up time, wich is most likely 2x of what the UPS box says in your case
9800X3D - NH-D15S - MSI X670E  -  32GB 6000MHz CL30 - RTX 3080 FTW3 - 970evo 1TB - 980pro 1TB - 970evo 1TB - 970evo+ 2TB -  970evo+ 2TB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i -  27GR95QE-B.AEU - 28MQ780-B - 27GP850-B - 27GL850 - Meshify 2
https://linustechtips.com/topic/402949-ups-power/#findComment-5433062
A 1200VA UPS is enough for 750W psu . is not it ?
It's not about the VA only you need to check what the wattage rating on that unit is also, not to mention it doesn't need to be a larger wattage than your PSU just larger than the total power consumption at max load.
What unit are you looking at currently?
https://linustechtips.com/topic/402949-ups-power/#findComment-5439227
