980ti low fps...
Go to solution Solved by DigitalHermit,
Try a clean reinstall of the drivers and try again...
Zotac 980ti AMP!
with my 780 6GB i got 130 ish fps in cinibench and im getting the same with the 980ti
titanfall, no improvement still around 120 fps (but i had to use LESS MSAA) I should be getting 144 easily at full 8x MSAA
I dropped 970$ with tax on this card...
Im about to try 3dmark where i used to get around 8000
Just tried to run firestrike and nvidia graphics crashed -_-
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/402635-980ti-low-fps/
UPDATE:
GPU usage in cinibench maxed out at 61% but stayed around 40%
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428607
What driver you running?
350.30
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428623
Thermals and clock speeds?
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428664
under 68C for temp and core clock went up to 1265mhz
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428669
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428675
Already done, just got 14036 in firestrike so looks like just something stupid with opengl in cinibench
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428706
Try checking your temps for the CPU and CPU usage, that can be the problem, I had the same issue with my 970, the problem was poor cooling because I used the stock cooler, and my temps hit 90c in games
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428723
Already said, under 70C whole time
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428736
What resolution is this happening in?
1080p
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428738
Do you have any of these games? Do you framerates match up?
Turns out i just needed the driver reinstall and open gl is just kinda shitty.
im at +200 core and +700 on the VRAM and its not breaking a sweat under 72C
https://linustechtips.com/topic/402635-980ti-low-fps/#findComment-5428833
