Hello people of the internet, I need help for ma brand new x99s sli plus motherboard.
So I built everything, did all the cable management, installed all the drivers and the time came for overclock. So I tried to get 4.5 Ghz on a 5820k, it didn't boot, I was going for 1.28v. So I decided to go more slowly and put it at 1.3v for 4.2 Ghz, I'm cooling it with a 360 push pull dedicated rad. The thing is though, now it won't boot after trying 4.2 Ghz on 1.3 V. However I flicked the switch to bios B and there it boots fine. As I really don't feel comfortable to have only one bios available in the case that something happens I'd like to get my Bios A back, but I'm not sure how to go about it since Bios A won't post at all.
https://linustechtips.com/topic/402209-another-no-post-issue/
read the manual, there's probably a reset switch on the board itself
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
https://linustechtips.com/topic/402209-another-no-post-issue/#findComment-5422396
Click Bios 4. See if you can restore bios A to defaults
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/402209-another-no-post-issue/#findComment-5422407
