Hello, i have been looking around for a pc that can run things like League of Legends and/or Minecraft at 60fps in medium settings. I also would like to play the Dolphin emulator,(wii and gamecube) and play super smash bros melee/brawl on netplay(playing online) at 60fps. Most builds i looked at were around $450 and i tought they were great, but did not include price of Windows OS, and monitor(i dont have one, this is my first pc) and they ranged over $600.
I dont have a clue what cpu and gpu i need for these kind of games. I asked my friend, who recommended this (http://www.ibuypower.com/Store/AMD-FM2-A-Series-APU) I liked the idea, and chose what i wanted, but in the end, with a monitor and the OS, it ended up being $715. I really dont want to get to the price range above $600.
What i am asking for is a build recommendation under $600(INCLUDING OS AND MONITOR) to fit for what i am looking for. I dont really mind the size of monitor, i just want it to be under 17 inch and above 15 inch, and would like it to be less than or $100. It would be great to get advice on upgrading it too, like a better graphics card if i ever want to run more things.
https://linustechtips.com/topic/401953-gaming-pc-build-help-us/
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  ($50.99 @ SuperBiiz)
Storage: Mushkin Chronos 60GB 2.5" Solid State Drive  ($45.98 @ Newegg)
Video Card: Sapphire Radeon R9 270X 2GB Dual-X Video Card  ($161.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($32.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($24.99 @ NCIX US)
Monitor: Acer V206HQLAbd 60Hz 19.5" Monitor  ($91.99 @ SuperBiiz)
Other: Windows 8.1 pro key ($25.00)
Total: $605.79
Generated by PCPartPicker 2015-07-06 22:14 EDT-0400
https://linustechtips.com/topic/401953-gaming-pc-build-help-us/#findComment-5419480
Total: $605.79
Its his first pc and you're going to give him multiple drives... i don't know if that will work out with his lack of experience.
https://linustechtips.com/topic/401953-gaming-pc-build-help-us/#findComment-5419561
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($27.99 @ NCIX US)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($45.99 @ SuperBiiz)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($54.89 @ OutletPC)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($40.50 @ Amazon)
Video Card: MSI GeForce GTX 750 Ti 2GB Video Card  ($138.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($39.99 @ NCIX US)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Newegg)
Monitor: Dell E1914H 18.5" Monitor  ($79.99 @ Micro Center)
Other: Windows 8.1 Pro X64 Key ($20.00)
Total: $568.22
Generated by PCPartPicker 2015-07-06 22:33 EDT-0400
Simple. Not sure why you want a tiny monitor but to each their own I guess.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/401953-gaming-pc-build-help-us/#findComment-5419590
Total: $568.22
I dont have much space on where my pc is going to be put in. and i dont like staring at big screens for too long...
https://linustechtips.com/topic/401953-gaming-pc-build-help-us/#findComment-5419857
Total: $568.22
Could you go into some detail on why recommend this? This looks great, but then again, i dont know if it is what i need.
https://linustechtips.com/topic/401953-gaming-pc-build-help-us/#findComment-5420071
Well using LGA 1150 let's you upgrade to a quad core i5 later on down the road, so you have a good path. 8GB RAM is more than enough to handle any programs running in the background while you game. An aftermarket cooler for the Pentium just in case you decide to get adventurous and play with the clock speed. 1TB hard drive is plenty of space and relatively quick. You could put a cheap SSD in too for your OS if you want something a little quicker but that's easy to do down the road. The N200 case is relatively small and cheap without being absolute junk, and the CX series of power supplies is good for a low-power build, and usually a good price. And last the GTX 750 Ti is an excellent little GPU, quick and power efficient, it'll handle anything you throw at it and it will love the low resolution monitor.
For an OS you can easily get a legit key off reddit for $20, or just download the Windows 10 Insider Preview as it will go full version end of the month. Supposedly anyone running the Preview at that time who is registered (5 second process, you're halfway there if you have a hotmail account) will automatically be updated to full release with a license.
https://linustechtips.com/topic/401953-gaming-pc-build-help-us/#findComment-5422077
