hey I had nowhere to turn so I come to you guys i have 2 questions
1) I have a intel i7 4700mq "lying around" and I want to chuck it into a mini-itx motherboard but theres all this AM1 stuff on the cheap motherboards which apparently means that my i7 wont work there, could someone reccomend a cheap motherboard (im talking under £50 if possible) that is compatibly
2)EDIT:question solved/proved impossible
Sorry for troubling u guys with this post but its kinda a nice project i wanna do
https://linustechtips.com/topic/401726-compatibility-help-plz/
Yeah that's not going to work...
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/401726-compatibility-help-plz/#findComment-5416544
Yep, you have to search for a notebook mainboard that supports the CPU (FCPGA946 also known as "G3" with a support for 47Watts TDP) and your decicaded GPU.
Pretty sure you won't find this under £50, since High-End notebook hardware is pretty pricey.
Also I don't know any notebook model or mainboard that support both of these aspects.
You can always mod some facny cooling on there, since you don't plan to use in in a Notebook (?).
But hardware wise, you have to use notebook parts for this.
~ ThxAndBye
"You should remove any cats from the vicinity, because cats will cause all kinds of problems during CPU installation." -Linus
https://linustechtips.com/topic/401726-compatibility-help-plz/#findComment-5416571
Like i said, you need a Notebook Mainboard for this. (FCPGA946 socket also known as "G3" with a support for 47Watts TDP)
Just search for a Notebook with that CPU, and search for a Mainboard from this model.
~ ThxAndBye
https://linustechtips.com/topic/401726-compatibility-help-plz/#findComment-5421226
