Hi guys!
Yesterday my headphones stared acting weird and only playing in stereo some times. Today they just use the right side... It's the "bend the wire and it's fine" problem, so whenever I bend the wire in a right spot they play in stereo. Is there any fix to this problem? :(
If not can you recommend some good ~50€ gaming Headphones? Mic is not necessary but can be included if it doesn't cut on the sound quality to include it.
Core2 Quad Q9400 @ 3.00GHz ✦  8GB Corsair RAM ✦Asus P5G41Tm - Lx3 ✦ Sapphire R9 270 Dual-X ✦ WD Caviar Green 640 GB ✦ Seagate Barracuda 160GB ✦ Fractal Design Define R5 ✦ 1Life ps:jet 700W ✦
Lenovo Y520 - GTX1050Ti - i77700k - 250GB Samsung M.2 NVME SSD  :D
https://linustechtips.com/topic/401556-headphones-only-using-right-ear/
Idk the value of the euro, but if you can try to pick up some hyperX clouds. Fantastic headset.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
Cut the cord open and fix it and tape with black tape?
Fix what? I don't know what will be inside it, and where to fix... Can you explain it any  better?
Ok, so where you have to twist it to get better audio. That's probably where the problem is.
If you cut open the cord there will be a couple of smaller cables. One is probably broken. Mend it together with some tape and the problem will probably be solved.
If it isn't solved then you were planning on buying another pair anyways :D
50 euro is around 55 american dollars.
Razer Krakens are fairly cheap ($50) and decent quality for the price.
You are on a need to know basis, and you don't need to know.
The cable must be broken, meaning the contact is severed and works only when the two pieces are touching. If you know exactly where they are broke, you can try to cut the plastic around the cable and use glue to make sure the contact is always happening, then cover it with tape. In general however I wouldn't recommend buying very cheap headphones (IEMs are different), and be careful when purchasing "gaming" gear as you often pay more than you should for that sort of thing. I can however recommend the asus rog orion headset, it's built like a tank and sounds pretty well considering the price.
sudo chmod -R 000 /*
Razer, gross. But seriously, Razer Krakens have pretty bad build quality and are way too bassy, and the bass isn't the best either.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
The wire inside is most likely frayed, if you have a warranty or return guarantee then claim it and get a new pair sent out, if not invest in some HyperX Cloud headphones
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
