HELP!!!
It has been a long time since i have been planning to get a gaming pc & to be honest im am tired of choosing parts for what i need.
I would like suggestions on what i would need for a gaming pc.
the main things i would be doing on my pc are:
  • 1080p 60hz gaming
  • games i am planning to play are: GTA V, CS:GO, far cry 4, Battlefield 3 & future games
  • light video editing for YouTube
  • running 2 screens (1920x1080 & 1440x900[i think])
  • does not overheat much (i know it probably wont but this current laptop is a pain in the ass with overheating)
i would like something with at least a intel quad core & i would like a Nvidia GPU but AMD could be okay as well
memory speed i don't mind but something with about 8GB minimum
storage i would like an SSD but not too small, & HHD i would want something big to store the games, programs etc on
cooling i would not care if liquid or air cooled.
My budget is about $2000 max or just a little over.
any suggestions ill keep in mind once i have the chance to buy the parts to build my pc
Thanks LinusTechTips Community  :)
https://linustechtips.com/topic/401505-help-gaming-pc-build/
HELP!!!
  • 1080p 60hz gaming
Do you care about looks or color scheme?
• OS: Windows 10/10 Pro  • SSD: Samsung 256GB 850 Evo Series *  • HDD: Seagate 1TB  • GPU: MSI GeForce GTX 1070 GAMING X (SLI)
• CPU: i7-4790K OC 4.7GHz Quad-Core Processor • Case: NZXT H440 (Black/Red) • PSU: EVGA SuperNOVA NEX 650W
• RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory • Mobo: MSI Gaming 5
https://linustechtips.com/topic/401505-help-gaming-pc-build/#findComment-5413079
My suggestion:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($146.98 @ Newegg)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($649.99 @ B&H)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Total: $1492.79
Generated by PCPartPicker 2015-07-06 08:26 EDT-0400
PS: Just add any monitor you want preferably 1440p with your budget
https://linustechtips.com/topic/401505-help-gaming-pc-build/#findComment-5413128
PCPartPicker part list: http://pcpartpicker.com/p/vqrpkL
Price breakdown by merchant: http://pcpartpicker.com/p/vqrpkL/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($299.99 @ Micro Center)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler ($111.99 @ Amazon)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard ($386.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2666 Memory ($149.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($97.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB Video Card ($649.99 @ Amazon)
Case: NZXT S340 (Black) ATX Mid Tower Case ($62.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ NCIX US)
Total: $1896.80
Generated by PCPartPicker 2015-07-06 08:43 EDT-0400
https://linustechtips.com/topic/401505-help-gaming-pc-build/#findComment-5413203
-Snip-
  • 1080p 60hz gaming
-Snip-
This is what I came up with, your budget is plenty high enough to get a lot of the best things on the market, and still have some leftover. So that's what I went with. Is it overkill? A little, but it also makes it a little bit more ready for the future, so it's alllll good.
Liquid Cooled, Hyperthreading, Black/White Build, and Runs 1440p 60fps High+ Settings.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($125.89 @ OutletPC)
Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1600 Memory  ($57.99 @ Amazon)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory  ($54.89 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($699.95 @ B&H)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($104.99 @ Micro Center)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($121.99 @ SuperBiiz)
Total: $1751.56
Generated by PCPartPicker 2015-07-06 09:34 EDT-0400
Now I threw in a Gigabyte G1 980ti, which works great, and looks ok with the build (As it is black). But there is a combination that matches the build better as far as aesthetics, and keeps the same performance. The difference is you have to set up SLI to do it.
I like this, it's the MSI 970 which by itself can run 1080p 60fps High+ Settings in almost every game, and when put in SLI matches the 980ti in performance. The biggest difference is they completely looks amazing with the MSI Black/White board.
4%20-%20Z97%20SLI%20Krait%20and%20GPU.jp
And here is the video comparing the 970 SLI with the 980 ti, so you can see they do perform the same, except the 970 will look much better with the build.
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/401505-help-gaming-pc-build/#findComment-5413461
Get a Fury X! :D
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/401505-help-gaming-pc-build/#findComment-5414549
This is what I came up with, your budget is plenty high enough to get a lot of the best things on the market, and still have some leftover. So that's what I went with. Is it overkill? A little, but it also makes it a little bit more ready for the future, so it's alllll good. Liquid Cooled, Hyperthreading, Black/White Build, and Runs 1440p 60fps High+ Settings. PCPartPicker part list / Price breakdown by merchantCPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($328.99 @ SuperBiiz)CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler ($111.99 @ Amazon)Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($125.89 @ OutletPC)Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1600 Memory ($57.99 @ Amazon)Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory ($54.89 @ SuperBiiz)Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($97.99 @ Amazon)Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card ($699.95 @ B&H)Case: NZXT H440 (White/Black) ATX Mid Tower Case ($104.99 @ Micro Center)Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($121.99 @ SuperBiiz)Total: $1751.56Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-07-06 09:34 EDT-0400 Now I threw in a Gigabyte G1 980ti, which works great, and looks ok with the build (As it is black). But there is a combination that matches the build better as far as aesthetics, and keeps the same performance. The difference is you have to set up SLI to do it. I like this, it's the MSI 970 which by itself can run 1080p 60fps High+ Settings in almost every game, and when put in SLI matches the 980ti in performance. The biggest difference is they completely looks amazing with the MSI Black/White board. 4%20-%20Z97%20SLI%20Krait%20and%20GPU.jp And here is the video comparing the 970 SLI with the 980 ti, so you can see they do perform the same, except the 970 will look much better with the build. https://www.youtube.com/watch?v=u4RyNNlKbJw
I was originally looking at the MSI SLI motherboard, it is in my thought of getting it. I have no thought of getting the GTX 980 Ti as I thought it is a bit overkill on what I need. The rest of the build I do like, and I'll try and mix it up a bit with the other suggestions I have been given.
I see you also have the i7 4790K currently in your build, out of curiosity have you overclocked it and by how much.
Thanks. :)
https://linustechtips.com/topic/401505-help-gaming-pc-build/#findComment-5418443
Thanks. :)
Yea, the 980 ti is overkill for 1080p 60fps. Which is why I recommended the 970. IDK where to get that MSI one I linked, as they just advertised it at CES 2015. But I know it would look great with that board and will handle 1080p 60fps High+ settings perfectly.
I have it overclocked mildly. Usually people go to 1.3v, I only went to 1.26v and got it up to 4.7ghz. I can get it to do 4.8, but I like my temps to stay below 70c, cause I live in a hotter State. :P
https://linustechtips.com/topic/401505-help-gaming-pc-build/#findComment-5418577
