What ram are you using?
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/401411-overclocking-help/#findComment-5411872
If you go into advanced mode, can you set the AI Overclock Tuner (In AI Tweaker) to XMP with profile #1?
Edit: Also, this may not be the case, but it may require two sticks since it is dual channel memory? It appears your board is only using one.
im only using 1 atm.
also there is no xmp profile in ai tweaker..
https://linustechtips.com/topic/401411-overclocking-help/#findComment-5412108
ASUS%20Z87-Pro%20BIOS%2010%20-%20AI%20Tw
Interesting. In that case, I do not know why it is not appearing for you. A quick search did not reveal whether 2 sticks was required for xmp or not. I would check to see if your board is running the latest bios, but beyond that I am not going to be of much help.
https://linustechtips.com/topic/401411-overclocking-help/#findComment-5412129
here.
also, even if i changed the multiplier.... change in speed does not apply... IDK what is happening...
what version of Bios am i running?
post-228784-0-43949100-1436174810_thumb.
post-228784-0-97465200-1436174914_thumb.
https://linustechtips.com/topic/401411-overclocking-help/#findComment-5412289
It tells you bios version at bottom of your image, scroll down to DRAM frequency what options can you set that to?
Are you using the correct save and exit option when you leave the bios after setting the cpu clock? (rather than just exiting)
Can you install CPUZ or something to check the clock speed in windows? you may need to put the CPU under load if you're using power save settings.
https://linustechtips.com/topic/401411-overclocking-help/#findComment-5412401
i can assure you that i save before i exited and also i ran cine bench and the cpu only ramps up to 3.2 ghz even the multiplier is changed....
ps. i ran at performance mode
https://linustechtips.com/topic/401411-overclocking-help/#findComment-5412671
Have you checked to make sure turbo and speed step are off?
Motherboard: MSI G45 | CPU: Intel i7 4790K | RAM: 16GB G.Skill DDR3 | SSD: 2x Samsung 840 Evo 256GB | Graphics: EVGA GTX 1080 FTW | PSU: Corsair HX650W | Cooler: Cooler Master Hyper 212 Evo | Fans: 6x Corsair SP120's | Case: NZXT H440 Razer Edition | OS: Windows 10
https://linustechtips.com/topic/401411-overclocking-help/#findComment-5421284
