I recently bought a CAT6 50ft. ethernet cable to get to my router downstairs.  I went to test the speeds of it and I got a steady 10.8 mb/s when downloading steam games. No other applications that used wifi were open. But when I went to speedtest.net I got a 90 mb/s download, 10 mb/s upload, and 13ms ping. I was confused. Shouldn't I be getting 90mb/s when downloading steam games and other things of the sort?
Internet specs:
CAT6 cable: http://www.newegg.com/Product/Product.aspx?Item=N82E16812189038
Motherboard LAN: Killer ethernet 2200
router/modem: Comcast 802.11n modem & router hybrid
CPU: Intel i5-4590  ll CPU Cooler: Cooler Master Hyper 212 Evo ll  Mobo:  Gigabyte GA-Z97X-Gaming 7  ll  RAM: 4x4GB (16GB) Corsair Vengance  ll GPU: EVGA GTX 1070 ll PSU: EVGA NEX650 G1 80+ Gold ll Storage:  Segate 7200PRM 1TB HDD , MX100 256GB SSD ll Case: CM Storm Scout 2 Advanced w/ modded window ll  Display: Insignia 22' 1080p Tv ll  Speakers: Logitch Z313 w/ subwoofer  ll Keyboard: Logitec G910 ll  Mouse: Logitech G502 HERO
https://linustechtips.com/topic/401390-ethernet-issues/
90mbps is 11.25mb/s. So you get exactly what you should be getting.
https://linustechtips.com/topic/401390-ethernet-issues/#findComment-5411523
Steam measures speed in MB/s, whereas speedtests measure it in Mb/s.
8Mb = 1MB.
90Mb/s / 8 = 11.25MB/s
https://linustechtips.com/topic/401390-ethernet-issues/#findComment-5411527
No, since the download speed from Steam depends on THEIR servers, not your connection speed.
Download speed also depends on your HDD write speed.
From your post I take it you're using WiFi, so there's another bottleneck, since WiFi is generally slower than a LAN connection.
Speedtest only shows you your maximum down/up (to put it in rough terms) which you can use to compare the speeds promised from the ISP to what you actually get.
Also, what people previously posted
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/401390-ethernet-issues/#findComment-5411533
he is getting exactly the speed he measures.
https://linustechtips.com/topic/401390-ethernet-issues/#findComment-5411535
8Mb = 1MB.
Oh, ok. Sorry, I didn't there was a difference between the two.
https://linustechtips.com/topic/401390-ethernet-issues/#findComment-5411537
I forgot that they measure differently (steam in MB/s and speedtest in mbps)
https://linustechtips.com/topic/401390-ethernet-issues/#findComment-5411542
