I may be able to get a cheap 980 reference and I am wondering how it will perform temperature wise.
My MSI GTX 970 never goes over 66c at 1.3v 1550MHz in my Air 540, what can I expect?
I may BIOS mod the 980 reference if the temps allow.
https://linustechtips.com/topic/401061-980-reference-temps/
Got a 980 reference and now: 48 degrees.
Under load? I highly doubt that on reference blower..
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406579
Pretty sure people see like 85Cish. :)
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406594
Hmm will have to see then
must be idle.
That hot at idle? D:
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406605
Nope, Idling around...
But I got myself a custom Fan speed setting so it doesn't get over 60 degrees...
But Room temperature around 30 degrees
Why that hot..
Mine doesn't go above 30c..
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406619
reference will run at 79/80 by default fan curve. You can reduce the temps to like 73-75C if you turn on the fan 100%.
I personally am seeing about 84C right now with the hacked bios at 1.31v and 1545 mhz core / 8000 mhz memory.
If I set the power slider to 125% in afterburner I have no throttling either.
So besides the noise it's fine.
However because of the noise I'm on the backorder list for the EVGA Hybrid cooler kit.
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406643
So 84C at 1.31v under load at 100% fan?
Oh god I couldn't stand 100% fan speed on ANY blower.
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406662
84c under load but that is with a stock fan profile, you can easily keep it under 80c with a little noise.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406692
Hmmm..
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406699
Why that hot..
My 970 idles at 48-50C with 3 monitors and the fans at 560RPM. With the fans off it sits at 62C.
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406730
Hmmm..
I do mean little, I have a reference 780ti OC'd and it still never goes above 80c unless it's 99% load for minutes at a time. And the only time I hear the fan is when the room goes silent and my headphones are off. I would be surprised if the more efficient 980 can't do even better.
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406740
Use Nvidia Inspector Multi Monitor Power Saver.
Mine with 3 monitors never goes above 30c
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406741
Oh dear, no BIOS modding for me then..
totally worth it man. my firestrike score went from like 13,000 to 16,0000 by doing the bios mod and setting the fans to 100% at 80C.
going from a heavily OC'd 970 to a reference 980 will yield about the same performance.
http://www.evga.com/Products/Product.aspx?pn=400-HY-H980-B1
^ Get that when it comes back in stock.
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406759
Can't afford anything above what i'm buying dude but maybe some day lol.
I care more about real world performance than fire strike score :P
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406795
They go hand-in-hand. Increases in benchmarks like firestrike and valley correlate very well with FPS increases in games.
To recap:
OC'd 970 = reference 980
OC'd 980 is a 18-23% FPS improvement.
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406827
To recap:
For only an extra £50 if I can sell my 970, it seems worth it.
Also if I can sell it off and get something even better then YOLO
Yes that's quite normal especially in the summer and depending on the case and airflow.
UK and Corsair Air 540 master race
https://linustechtips.com/topic/401061-980-reference-temps/#findComment-5406877
