BenQ GL2450 LED Monitor - HDMI Problem
Solved by Guest,
I have the same monitor, seems like they shipped out a few with the "auto detect input" feature set to off. Connect your PC via VGA, then open the monitor menu with the buttons on the side and go to the last tab, there are a few input setting you might wanna set to "auto" or "on". After that HDMI will work.
Featured Topics
GOATWD ·
Posted in Operating Systems3 -
Wubb ·
Posted in New Builds and Planning2 -
erico2304 ·
Posted in Troubleshooting1 -
aisle9 ·
Posted in Peripherals1 -
5
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
2
