Hello Everyone,
I'm currently making simulations in Solidworks and am confused.
I have to double the force on a pulley and change the dimensions from the original pulley, in order to withstand the new force.
My hypothesis:
If I multiply all the dimensions by the cubed root of 2, then my volume will double and the results of both simulations will remain the same, because I doubled the force and the volume of the second experiment.
Does that make sense?
I figured if the volume of the object doubles along with the amount of force, then the results should remain the same.
When i ran the simulation, it didn't go as planned.
Why?
Thank You so much!
https://linustechtips.com/topic/400102-force-question-whos-smart/
