Just put the motherboard on, align the MIDDLE standoff in the center of the case and screw in the 8 screws on the outside of the motherboard.
CPU: Intel Core i7 5960X @4GHz cooled by a Corsair H110i GT | MBO: Asus X99 Sabertooth | RAM: Crucial Ballistix Sport 32GB DDR4 (4x8GB 2400MHz) | GPU: Gigabyte G1 Gaming GTX 980 | SSD: Samsung SM951 M.2 SSD | HDD: 1TB Western Digital Black Drive | PSU: Corsair HX750i | Case: Corsair Obsidian 450D
https://linustechtips.com/topic/400090-mobo-installation-help/#findComment-5393389
Check the case manual? Usually it tells you which ones are installed at certain points. The one you mentioned is probably the middle one for you to set it on for easy installation of the rest. Check the second one and see if it's mentioned anywhere in your case manual. Picture might help.
https://linustechtips.com/topic/400090-mobo-installation-help/#findComment-5393390
If Im referring to the one standoff youre talking about, thats just to hold the motherboard in place for the time being, you need to screw in the other 9 (I think?) screws into the correct holes that are already on the case's motherboard tray.
EDIT - Hopefully my artwork is of some assistance
https://linustechtips.com/topic/400090-mobo-installation-help/#findComment-5393394
What size screws?
The ones that came....with the case...
https://linustechtips.com/topic/400090-mobo-installation-help/#findComment-5393404
8 or 9 I can't remember :/
https://linustechtips.com/topic/400090-mobo-installation-help/#findComment-5393407
There's like 3 packets.
Check your manual then...
https://linustechtips.com/topic/400090-mobo-installation-help/#findComment-5393418
