Long story short. I have an old motherboard that has integrated support for 10/100mbps only. I pay for 200mbps internet. I am connected through a LAN cable from my router at the moment. If I buy a wireless network adapter that goes into my computer and supports 300mbps and I connect my computer through WI-FI will I be able to reach speeds of over 100mbps? Obviously not even with cable I can't realistically get exactly 200mbps but will I get at least 150-170mbps?
https://linustechtips.com/topic/399961-wireless-network-adapter/
maybe
depends on router
tho you would be better off buying a new network card
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/399961-wireless-network-adapter/#findComment-5391642
I'd get a gigabit PCI-E network card but my motherboard is too old for that stuff, I can only fit my GPU in there. There's no more PCI-E slots.
no pci slots?
https://linustechtips.com/topic/399961-wireless-network-adapter/#findComment-5391665
There's a PCI slot but no network card matches its pattern. It's definitely not an express slot.
thats probably a normal pci slot
https://linustechtips.com/topic/399961-wireless-network-adapter/#findComment-5391689
