Hi guys, I'm torn and need help. I am currently running dual XFX HD7970 but I want to upgrade my GPUs to take advantage of VSR. Price is of no concern should I buy the R9 295x2 now or should I wait a little for the new HBM memory tech to reach the 295x2's level? But I don't want to wait to long, I have a itch for a new GPU and it needs to be scratched BAD!
My Pc specs
Asus Crosshair V formula-Z MB
FX 9590 on a 280mm RAD
16gb Corsair Dominator Platinum 2133
Samsung EVO 250gb ssd  and 1 2tb hhd
SoundBlaster Z sound card
1200watt PSU
and 9 case fans
23" LG 1080p IPS 10 point touch screen
https://linustechtips.com/topic/399125-need-help-choosing/
Yeah, the 295x2 should be your best bet, as long as you can keep up with the heatout put and power consumption, but I see that you have a 1200W PSU, so you're fine
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/399125-need-help-choosing/#findComment-5378897
My Pc specs
1200watt PSU
and 9 case fans
I may be wrong but you should be able to enable Super sampling in Catalyst with your current cards. I'm pretty sure its similar to VSR, maybe just a little more dated in terms of performance but still useful.
post-239884-0-59168600-1435861683_thumb.
CPU i7-4770k @ 4.5GHz Motherboard MSI Z97M Gaming RAM 2x4Gb Patriot Viper @ 1866Mhz GPU EVGA 1080 FTW Case Corsair 750D Storage Intel 730 series 240GB + Segate Baracuda 3TB PSU Corsair HX850 Displays Philips 242G5 (Main) + Asus MX239 Cooling Noctua NH-D14 Keyboard Steel Series Apex Gaming Keyboard Mouse Razor DeathAdder 2013 Sound CA DacMagic Plus + Schitt Valhalla 2 + KRK Rokit Powered 6 + HD650
Operating System Windows 10
https://linustechtips.com/topic/399125-need-help-choosing/#findComment-5378913
Why pay more for a 980 TI when the 295x2 still crushes the Titan X? That don't make sense to me.
Ummmm......
980Ti outperforms the 295X2
Costs the same (and is in a lot of cases cheaper) as the 295X2
Is only a single GPU
Puts out less heat
Takes less power
Won't cause global warming
Is quieter
Newer architecture
Will have better suppourt in the future
Better drivers
What was that again?
crushes the Titan X
"I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party."
-Ron White
https://linustechtips.com/topic/399125-need-help-choosing/#findComment-5380665
Ummmm......
Puts out less heat
Takes less power
Is quieter
Newer architecture
Better drivers
 I have watched 100 benchmark videos on YouTube and I've never seen the 980TI out perform a 295x2.   My concern is buying a 295x2 now and AMD releasing a newer better version in a few months
https://linustechtips.com/topic/399125-need-help-choosing/#findComment-5380881
