PSU with sleeved cables
Looking for a PSU that provides sleeved cables like the ones with the CS psus from corsair, but their 24 pin isnt modular and isnt sleeved like the rest of the cables
Is there a fully modular power supply (So it doesnt use one big cable, instead the ones you attatch) that are all sleeved like the ones with the CS psus?
Basically like that, but the 24 pin isnt attatched, and its sleeved.
Also I have some questions about cable management with these cables, and my case, but first I need to find a power supply, so i'll create another thread once I do
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/
Normally ppl buy the psu and sleeved cables separately
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/#findComment-5376581
they're modular
I have it, its modular but not sleeved
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/#findComment-5376604
they're like $100 for a set tho, and i dont mind black
Your not gunna find a sleeved fully modular PSU under 150$ so if u get a 750 watt  evga G2 for like 70$ u can buy the cables sleved for only the cables u need, maybe 60$ more
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/#findComment-5376611
well i dont really know about sleeved, but whatever the photo has, which i dont mind
EVGA G2 is better. Any PSU in that line up.
Or any modular seasonic
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/#findComment-5376621
https://pcpartpicker.com/parts/power-supply/#m=14,71,63&p=1&sort=a9&page=1
Look in that list, they are all FULLY modular
NOTE: i have an RM 850 but the RM 850i is the new model
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/#findComment-5376626
whats wrong with corsair lol? I like their new black and white RMis
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/#findComment-5376658
-SNIP-
Those are not sleeved cables they are black ribbon cables for a fully individual sleeved PSU either a sleeved kit or the Bitfenix Fury PSU which is the only one that comes sleeved from the factory.
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/#findComment-5379842
Bitfenix and Silverstone make PSUs with nice sleeving.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/398936-psu-with-sleeved-cables/#findComment-5380316
