I don't know anything about this other than what ASIC's stand for, if it's an application specfic IC then I would assume that would be faster.
https://linustechtips.com/topic/398512-fpga-vs-asics/#findComment-5371993
FPGAs are good for really large numbers and can do whatever you want them to. ASICS are application specific in the circuitry design so they're faster but you'd have to find one made for exactly what your running which would be hard. So I'd look at dev boards with the Spartan 6 FPGAs perhaps.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/398512-fpga-vs-asics/#findComment-5372005
If you can find an ASIC for your exact need, it will be faster, albeit more expensive. Should be quite a lot faster than anything else though.
Silverstone ML08  ||  Intel i5-6600  ||  Gigabyte HD 7950 @ Stock  ||  Corsair 2x4GB DDR4 2133MHz  ||  Gigabyte H170-N WIFI  ||  Samsung 840 Pro 128GB  ||  WD Caviar Black 1TB  ||  MSX 64-bit
https://linustechtips.com/topic/398512-fpga-vs-asics/#findComment-5372044
