I currently have a really small case because it is an OEM HP pc (I know)... The GPU is really weak, it is an GT520.
The maximum size is about 200mm.
I do use CUDA because I have adobe CS6 on my pc and i'm not going to trow it away lol.
To make it clear:
-Max size 200mm
-CUDA (so NVIDIA is preferred, unless you know a good way to render in Premiere CS6 on AMD)
-Would be nice to have almost no power consumtion (max 100w or something)
Or should I wait till the next generation get's released which is probably more power efficiënt and smaller
MSI GT70-One-899NL | i7-3630QM | Nvidia GTX675MX | 12GB 1600mhz ddr3 | 128gb mSata ssd | 1TB hdd | 17.3 Full HD non-glare | Killer E2200
https://linustechtips.com/topic/3982-best-small-gpu/
I will look into the 660ti amp, but not sure if it is available here. Atleast I didn't saw it in the common computerstores in the netherlands
https://linustechtips.com/topic/3982-best-small-gpu/#findComment-49138
You might have to order it online somewhere. I know that Zotac is more common in Asia and parts of Europe.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/3982-best-small-gpu/#findComment-49165
