Hey guys, I'm building a gaming rig and i need help picking a CPU. Intel and Amd are both fine and the total build max is around $1200 but would like the cpu to be no more than $200.I plan on playing games such as battlefield  and crisis on high/ultra 1080p at at least 60FPS Any help would be appreciated! thanks!
https://linustechtips.com/topic/397751-need-help-picking-cpu/
4690k is pretty good and can be bought for 220 bucks. It'll last a very long time too. I believe its the best i5 on the market currently.
MainRig- CPU: 4790k, RAM: 32gb 2400mhz, MOBO: Maximus Formula VII, COOLING: Full EK cooling, GPU: Titan X SLI, PSU: 1200w evga , STORAGE: 250gb SSD, 4TB hybrid CASE: 760T, EXTRAS: Sleeved cables
SecondRig- CPU:4690K, RAM: 16gb 1600mhz, MOBO: Maximus Gene VII, COOLING: H105, GPU: 970ftw, PSU: EVG650W,  STORAGE: 250gb SSD, 3TB, CASE: 540air
Steam: pizzatime6 Plus two other pc rigs and a craptop.
https://linustechtips.com/topic/397751-need-help-picking-cpu/#findComment-5362638
Go with a 4690K, you can find it for $200 at some stores.
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
https://linustechtips.com/topic/397751-need-help-picking-cpu/#findComment-5362641
If you really want to maintain a solid 60 FPS then an Intel i5 is the way to go. The one you select will depend on how much you've allotted to the motherboard and how much you're willing to spend on the CPU... like there's no point in getting an unlocked 4690K for overclocking if you're not also getting a Z97 motherboard.
The dirt cheap option is to get any first-gen Haswell i5 like an i5-4430, 4440, 4570 or 4670 matched with an H81 or B85 board. The mainstream option (and what I'd recommend) would be to get either an i5-4460 or i5-4590 paired with an H97 chipset motherboard.
edit:
Yeah if you're going with an AIO liquid cooler and want to overclock, then you're looking at getting an i5-4690K and a Z97 motherboard. AMD's best option for the similar price range is the FX-8350 with a 990FX motherboard, however for gaming the FX CPUs fall behind the Intel... I'd only really recommend them if the bulk of your workload is video rendering, VMs, etc.
Intel i5-4690K @ 3.8GHz || Gigabyte Z97X-SLI || 8GB G.Skill Ripjaws X 1600MHz || Asus GTX 760 2GB @ 1150 / 6400 || 128GB A-Data SX900 + 1TB Toshiba 7200RPM || Corsair RM650 || Fractal 3500W
https://linustechtips.com/topic/397751-need-help-picking-cpu/#findComment-5362654
I was also planing runing the corsair h50 water cooler if that makes a diffrence
Your max temps will be around 50c with that cooler. The 4690k is great for overclocking and will last a great amount of time! Might be worth it to spend that full 200 for a cpu that will last a bit longer.
https://linustechtips.com/topic/397751-need-help-picking-cpu/#findComment-5362709
im on pcpart pick and its 280 at newegg and thats the cheapest :(
https://linustechtips.com/topic/397751-need-help-picking-cpu/#findComment-5362751
I got mine on newegg for 220.
https://linustechtips.com/topic/397751-need-help-picking-cpu/#findComment-5362823
Yeah see if you can grab a 4690K :D, if not then maybe see if there is a few discounted 4670K's somewhere or maybe go for a 4460/4590?.
Dammit AMD, i'm sure we're getting bored of reccomending i5's already, hurry up with zen :C
Hey bro i like yo *vomits on you*
SpOOkY  - Intel Core i7 4820K - Sapphire Radeon HD 7970GHZ Toxic Edition 6GB - 16GB Corsair Vengeance 1600Mhz - Gigabyte X79-UD3 - EVGA Supernova G2 850W
My GrApHiCs DeSiGn TeAcHeR Is GoInG To bE sO MaD
https://linustechtips.com/topic/397751-need-help-picking-cpu/#findComment-5362919
