Noisy Hard Drive Heads
Go to solution Solved by Captain_WD,
HereyouGo :]
According to the S.M.A.R.T. the drive is completely healthy so I'd say you are safe. I'd look around for comments on this drive and see if other people have problems with it being loud. You can always contact the manufacturer and see what they have to say about this plus they can give you some useful advice and tips. :)
Captain_WD.
PS: I simply love the wallpaper!!!
I have some OEM 300 GB Samsung Hard Drive im using until my 1tb WD Black comes in the mail, and the Heads are really loud, is this the sign of a dying hard drive? is there any way to replace it? or just a crappy drive.
http://gyazo.com/d14172fd04f47943bdabfc2c9efff57e
AMD A10 7700k APU @ 3.8 GHz  /  Dem Integrated R7 graphics  / 8 GB Crucial Ballistix DDR3 1800 MHz RAM  /  1 TB WD Black HDD  /  ARC Midi R2 Case  /  ASRock FM2A88M Pro 3+
Logitech MX Performance / Razor Blackwidow Ultimate
https://linustechtips.com/topic/397471-noisy-hard-drive-heads/
Define loud, is it a constant whir? Or a rattle-type sound? Or a screech? The WD Black is a louder drive naturally compared to a blue or similar-tier barracuda.
Also run crystaldiskinfo
It's more of a rattle whenever the hard drive actually does work (moves files, installing, casual browsing, etc.)
Here's the crystal disk info report: http://gyazo.com/053851d4c7811c7111e8c88133a321ca
https://linustechtips.com/topic/397471-noisy-hard-drive-heads/#findComment-5358771
I'd say it's fine to use for now, but don't put data that you would care about if you lost it on there.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/397471-noisy-hard-drive-heads/#findComment-5358883
Hey kgorringe,
Could you post a screenshot of the bottom part of the test (the S.M.A.R.T. results)? A drive can be loud for a number of reasons. I would suggest using the diagnostic tool provided by the manufacturer jsut to be on the safe side it is OK.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/397471-noisy-hard-drive-heads/#findComment-5364637
Hey kgorringe,
Captain_WD.
HereyouGo :]
post-232780-0-42727400-1435957500_thumb.
https://linustechtips.com/topic/397471-noisy-hard-drive-heads/#findComment-5391006
HereyouGo :]
Captain_WD.
https://linustechtips.com/topic/397471-noisy-hard-drive-heads/#findComment-5412197
