Okay so basically, I'm planning out my new build, and I have a budget of 3k $
is it going to be enough for an X99 build?
Question : will skylake use the 2011-v3 chipset?
Monitor/Peripherals and the OS are not included
I live in the United Arab Emirates (google it) and the prices are a bit higher here when it comes to PC parts and such.
I currently use an
i5 3570k
GTX 970 4G
600 w PSU from gigabyte
and 32 gigs of DDR3 Ram
anything should I salvage from my old build?
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/397080-3000-x99-build-help/
Thats a pretty beefy computer to begin with, what do you want to upgrade for?
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5354227
Dont build a new system, please, dont.
If anything, upgrade to Z97 and throw in another 970 and THATS IT.
And maybe new PSU.
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5354232
Come on guys, he clearly wants a new toy to play around with  :)
Now considering I don't know exactly how different the prices are around there, I'd say the best bang for your buck would be a z97 build with a 4790k with a good AIO water cooler and 2 980ti. It's just my guess though... Could you give us a web site or something that we can use as reference?
Oh and about your ram, could you tell us what frequency they run at?
CPU: Intel Core i5 4690k @4.7Ghz_1.33v ||| Motherboard: Asus Z97 Pro Gamer ||| RAM : HyperX Beast 16GB 2400mhz ||| GPU : 2x MSI gtx 970 4G SLI |||  Case : Corsair Carbide 500R ||| Storage : 4x Crucial MX100 250GB RAID 0 |||  PSU : Corsair RM850 |||  Display : RoG Swift |||  Cooling : Corsair h110 |||  Keyboard : Asus Strix Tactic Pro Cherry MX-Red |||  Mouse : RoG Gladius |||  Sound : Xonar U7,  Sennheiser HD 558 , Logitech z5500, Strix 7.1 Pro ||| Operating  System: Windows 10
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5354321
And maybe new PSU.
Mate, I am going to cry if you spend $3000 on a new computer when you already have a system as good as that!
I want to buy a new system just for the sake of buying a new system, I know nothing is wrong with mine at the moment, but I'll have it a secondary PC if anyone comes to my house and wants to play games and such, but for my system, I want a beefy PC that can run anything maxed out on all settings, while staying 60 FPS
I also want to get an X99 board because its new, and why not? I have the money for it.
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5355058
He wants an X99 build, not Z97.
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5355066
can it possibly be an X99 board?
I'm going to use this website : http://uae.dtcae.com/ to buy the parts from,, although they still don't sell the 5930k I will try to look for it in stores in here, if no luck, I will order it from amazon or something
my ram currently runs @ 1600 Mhz, but its a 2400 Mhz ram, its limited by my motherboard that I have right now which is a Gigabyte-DS3H-H77
Edit : the store sells the 5930k
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5355067
What kind of stuff do you do on your computer?
I will be starting a youtube channel, so I'll need it to render 10-15 minute footage in 10 minutes or less, I also will be doing heavy gaming, triple A title games will be played, a lot of streaming too, and photo editing
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5355086
If that's the case, then an X99 board (I'm not so familar with them), 5820K (or 5930K if you plan to run 3-way SLI) and a GTX 980 Ti (make sure it has a custom PCB). That would be an absolute monster rig.
EDIT: However, $3000 is still a lot to spend on a PC. It won't be as quick, but a 4790K would still be pretty damn good at rendering videos. Not to mention that the motherboard and RAM will be cheaper (by a fair margin).
The way I like to see it is: Does your source of income ABSOLUTELY depend on your PC and your wellbeing is dependant on the performance of said PC? Go X99. Otherwise, go Z97.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5356283
You see, I'm an enthusiast, and I really want to build on the X99 chipset, and I want DDR4 and all of that goodness, money is not a problem for me at all, I can go over my budget if needed too.
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5357517
I currently use an
i5 3570k
GTX 970 4G
The upcoming Skylake is LGA 1151.
Broadwell-E is supposedly Q1 2016 and will use the current X99 LGA2011-3 platform. Skylake-E is supposedly Q3 2016 and that might use a different platform altogether.
Source:
http://wccftech.com/intel-processor-roadmap-leaked-10nm-cannonlake-skylakee-arrives-q3-2016-skylake-muy-chips-q4-2015/
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5357648
Source:
so whats better in the long run? 2011-v3 or should I wait for Skylake?
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5357743
Well the 2011-3 platform has the stronger cpu lineup i.e 6 and 8 core.
The upcoming Skylake will be similar to current Devil's canyon i.e 4 core.
If you want an enthusiast build then stick with 2011-3
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5357813
If you must...
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($378.99 @ SuperBiiz)
CPU Cooler: Corsair H110i GT 113.0 CFM Liquid CPU Cooler  ($129.99 @ Mac Mall)
Motherboard: Asus SABERTOOTH X99 ATX LGA2011-3 Motherboard  ($309.99 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2666 Memory  ($159.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($174.99 @ Amazon)
Storage: Western Digital Caviar Black 2TB 3.5" 7200RPM Internal Hard Drive  ($115.00 @ Amazon)
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked+ ACX 2.0+ Video Card (2-Way SLI)  ($679.99 @ Amazon)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($188.99 @ Amazon)
Total: $2917.91
Generated by PCPartPicker 2015-06-30 12:05 EDT-0400
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5357986
If you must...
Total: $2917.91
Thanks a lot! I love the H440, one question tho why not the Gaming G1 980 Ti's ? I heard they're better at cooling and better overclockers
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5358153
alright awesome, thanks :)
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5358163
Sorry I'm late to the party  :P . The build mentioned above is what I had in mind but since you said the prices there are a bit higher, I gave priority to the massive GPU's (I guess I'm a bit biased xD ) and hence lowered from X99 to z97 to keep within your budget (I also asked about the RAM to see if it was worth salvaging for a z97 build). If you go for the above build you'll have a beast system and it is very unlikely that skylake will have better performance since it's going replace the "mainstream" platform while x99 is theiur "enthusiast" grade hardware to begin with. Have fun with your new PC  :)
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5358833
oh okay :) thanks! I wont be building this until my new house is built, so I need to sort everything before getting it :P
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5358889
You can swap them I suppose ^_^ Just depends on what is available in your area.
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5358928
oh yeah, I should've thought of that :P thanks!
https://linustechtips.com/topic/397080-3000-x99-build-help/#findComment-5359383
