help with waterkoeling
Go to solution Solved by WoodenMarker,
The Zalman cooler seems to be the performance/sound efficient one :http://www.tomshardware.com/reviews/h100i-elc240-seidon-240m-lq320,3380-13.html
I've been searching for watercoolers, and saw there where a lot .. 120mm thick, flat, one fan, two fans, flat 240mm.
so, i've saw 3 coolers that might be something .
what is better? a thick 120mm with one fan ( zalman lq320 ) or a thinner 120mm with two fans? (corsair H80i)
or maybe an thin 240 mm with two fans (corsair h100i)
https://linustechtips.com/topic/39660-help-with-waterkoeling/
https://linustechtips.com/topic/39660-help-with-waterkoeling/#findComment-511681
