I have a shitty little acre 1, i dont know the name of it for i cant find it anywhere, the computer was bout last year.
Onboard networking is typically enabled by default. Is it not recognising the cable when plugged in?
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/395894-lan/#findComment-5350113
Until you can give us the model number, we unfortunately can't help you.
My System has a Intel Core i7 4790k @4.5ghz Cooled by A Cooler Master Hyper 212 EVO With a MSI Nvidia GeForce GTX 1080 Founders Edition and 16GB of Corsair Vengeance 1600Mhz Memory.
https://linustechtips.com/topic/395894-lan/#findComment-5351679
yes, in windows 8 thing, it just says "limited" and wont even connect to it! im tired of how slow my wifi is and i want to fix it
If its detected it is turned on, if it was disabled in the BIOS windows wouldn't see it.
You'll need to check the settings of the card, make sure it is getting an IP address assigned by your router.
https://linustechtips.com/topic/395894-lan/#findComment-5357633
