When I try to defrag my hard drive (I only have a single 1TB HDD), it shows two drives - my hard drive, and a system reserved (I assume for Windows 8.1?) It says that the system reserved drive is 21% fragmented, how do I defrag that partition / drive?
Cheers & Best Regards,
Arcapse
https://linustechtips.com/topic/395852-defrag-system-reserved/
Disable the paging file, and then reboot.  You might also have to boot into safe mode.  Not sure.  Also try using MyDefrag.
https://linustechtips.com/topic/395852-defrag-system-reserved/#findComment-5340266
no point to defrag that partition imo.
https://linustechtips.com/topic/395852-defrag-system-reserved/#findComment-5340373
