Mouse problems...please help! ( logitech G502)
Hey guys..I just got my Logitech g502 a while ago and apparently the clicks stick to my fingers when I lift my hand from the mouse and it produces quite a loud noise. They stick even if I do not click...but like..touch the mouse with my fingers. I do not know if this is normal and if I should worry.
Here is my video I recorded a while ago:
https://www.youtube.com/watch?v=pDrGGPzRSaY
And here is another video of a guy that I found today: <removed by staff>
Can you guys, please, let me know if this also happen to you and if I should be worried about it? I really want to know if it only my unit (and apparently this guy's unit) or it something that happens to most of you.
I am waiting for your answers.
Best regards!
https://linustechtips.com/topic/395367-mouse-problemsplease-help-logitech-g502/
RMA it if its still in warrenty
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
I tried to! Even thought i was under the 30 days period when i can return it for whatever reason i want..the guys from the store told me they cannot replace it because i stated that the reason why i want to replace it is because the unit was defective and that they will only replace it in the first 14 days if the unit is defective (which makes no sense btw..since nowhere on their website says this..it only says replace it in the first 30 days for whatever reason). They told me to send it under the warranty service (which i did) but it came back after two weeks and their service said that the test was "ok". Basically they did nothing to it and they also damaged my box really bad.
I have no ideea what to do. Don't get me wrong..i love the mouse, it is really amazing..but this problem is anoying because every damn time i lift my finger i hear that loud noise. I want this to be fixed..but as i can see the guys from the store won't really help me. I even argued with them while i was under the 30 days period and they refused to accept a replacement. I kept telling them that my unit is not under the non returnable stuff list and that I am also under the 30 days of return policy but they just didn't want to listen. They kept telling me that because i stated that the unit was defective (so because i said the truth) they could only replace it in the first 14 days...and I actually asked for the replacement in the 14th day..even though I didn't know about this rule..and even after I told them this..they still refused..and as I said..they told me to send it in service..but there nothing happend.
What should I do?
Also..the mouse is not dirty, in case you thought about that as well. I just had it for about one month..and trust me i clean it ever single time i use it..even the mouse feet. I am really careful with my stuff.
Looks normal to me. If you want to minimize the problem, try washing your hands more frequently and also clean the surface of the mouse button so it won't stick so much.
There are more things in heaven and earth then are dreamt of in your philosophy.
