Headphones advice
Go to solution Solved by ShearMe,
Not more than 300-400€ which should be 335-446$
Sennheiser Momentums should fit in that budget. The 2.0 versions fold. On-ears are the same size, fullsized 2.0 has bigger cups than the original.
if you want that b-b-b-baaaasssssss http://www.amazon.com/V-MODA-Crossfade-Over-Headphones-Gunmetal/dp/B003BYRGKY then crossfade lp's are small and good.
ath m40x is also a good choice. Basically closed headphones.
https://linustechtips.com/topic/395018-headphones-advice/#findComment-5329544
https://linustechtips.com/topic/395018-headphones-advice/#findComment-5330896
