Hello my friends,
So today I was playing CSGO and my video driver started to crash, so I decided to restar my pc, but when i restarted it was black screen. Then i thouth it was it was my driver fault so I booted in to safe mode an uninstalled display driver and restarted, but when it boots in too windows in 5-10 min it goes to black screen and I can't install new driver. Once I managed to install them, but then it was black screen again. So is my grapichs card dead ( radeon 7850) or I can do something to fix it?
Thanks
https://linustechtips.com/topic/394633-problem-with-pc/
Probably dead if you haven't done any software change. Does your motherboard have an integrated GPU? Do you have an old GPU? Try using them to check it's a GPU issue.
But it's a dead GPU, i'm 100% sure.
AMD 860K @ 4.3GHz ; Kingston HyperX Fury 2400MHz ; Asus A88XM-Plus ; Sapphire R9 270X 2GB ; 600W Tacens Radix VII AG 80+Silver  ; Cooler Master TX3 Evo
https://linustechtips.com/topic/394633-problem-with-pc/#findComment-5325039
I checked my bios is up to date. Now I am using integrated GPU and it works fine.
Your GPU is dead then.
https://linustechtips.com/topic/394633-problem-with-pc/#findComment-5325181
