I think it takes the lowest speed and halves it.
it shouldn't
task manager sucks, use something like cpu-z.
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324701
DDR3 = Double Data Rate RAM version 3
It makes 2 operations every cycle, therefore 667MHz is in reality 1333MHz
AMD 860K @ 4.3GHz ; Kingston HyperX Fury 2400MHz ; Asus A88XM-Plus ; Sapphire R9 270X 2GB ; 600W Tacens Radix VII AG 80+Silver  ; Cooler Master TX3 Evo
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324716
CPUz takes 1866 and halves it to 933.
Edit: Because of what Kettchup says.
or not?
cpu-z is more reliable since it doesn't depend on how bad your task manager is. but I know it shows half the speed in cpu-z.
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324729
Everytime I reinstall windows it shows the same, I thought all task managers are the same, apart from the spec
windows 8.1 ftw. if you have 7 then it's not ftw.
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324779
Yeh, I've always ran 8.1, ready for Win 10 though :D
and it shows 667mhz in windows 8.1? what about cpu-z?
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324793
I have 2 1333MHz and 1 1600MHz RAM sticks.
In the task manager on Windows, it says it runs at 667MHz. Why is this?
Go in to your Bios check that it's running at 1333MHz don't go to 1600 you could kill the 2 1333 sticks
Either that or one of your sticks is fucked up, take 1 out at a time and see what the speeds say
CPU: i5-4690K @ 4.0GHz GPU: Gigabyte Gtx 970 WindForce MOBO: Gigabyte Z97 Gaming-3 CASE: Corsair Carbide 200R PSU: Corsair RM750
RAM: Corsair Vengeance 4GBx4  MOUSE: CM Mizar KEYBOARD: Logitec G110
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324881
Yes, it is running at 1333MHz. Wasn't sure if windows was limiting it. I believe that it half's it, as previous members have told me
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324905
I can't confirm or deny this but I've never heard it and it doesn't make sense to me, when you run two sticks of different speeds both sticks then get clocked down to the slower speed, take the 1600MHz stick out or run it by itself and see what happens
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324952
Will it make a big performance difference of the PC running at 667MHz? because it is really fast, mainly because of the SSD.
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324974
It's running at the slowest RAM Module speed, 1333MHz.
DDR non-effective ram speed for 1333 MHz it's 666/667MHz and that's what is showing you, it's simple.
Also, in the hypothetical case that it's running at 667MHz you won't notice a difference.
https://linustechtips.com/topic/394610-ram-speed/#findComment-5324999
I don't think it will make a huge difference but if you do what the best performance, buy another 4GB 1600MHz stick, it's pretty cheap, but unless you're gaming at high specs don't worry about it
https://linustechtips.com/topic/394610-ram-speed/#findComment-5325015
