mATX case help
Go to solution Solved by Sam Z Man,
If you have money.
-350D
-Arc mini R2
If you on a tight budget.
-I hear the Cougar Spike is good for being around 30$.
I need help,i dont know any easily installed mATX cases,so i need your help
my specs i have to put in there:
Intel® Core™ i5-4590 Processor with stock cooler
MSI B85M-G43 MoBo
Corsair CX Series™ CX600 PSU
2x Corsair Vengeance® Series  4GB (1 x 4) DDR3 1600Hz CL9 RAM
WD 3.5"SATA3 BLUE series 1TB 7200RPM 64MB  Hard drive
Sapphire Radeon R9 280X Dual-X Graphics card
so now i need a case to fit my components
please help!!! :(
Edited by UltraOmega19
https://linustechtips.com/topic/394220-matx-case-help/
