I recently switched from an iPhone 5S to an LG G3. I love a lot of things about it, but I have a lot of gripes too. More on that later. I have a couple gripes, as I previously said. These problems include finding a good messaging, camera, and podcast app. Keep in mind I switched from an iPhone, where all these apps are flawless. Any recommendations for apps? I also have a problem with the size of the phone. Again, I switched from a small phone to a phablet. I don't recommend this. I'm on Verizon, and I don't have an upgrade till March. I'm thinking of buying the One M9 at the end of July, is there a way I can sub in this phone to my plan to replace the G3? App recommendations are greatly appreciated. Thanks.
http://www.htc.com/us/go/buy-now-htc-one-m9/
https://linustechtips.com/topic/394175-android-advice/
When I got my G3, I was in a similar position, but I was coming from an iphone 4s, so the size change was even more pronounced (a full 2 inches).  A couple of my observations:
1) The stock LG messaging app is absolute garbage.  Group texting is nearly impossible because the UI freezes all the time.  I switched to hangouts and its been much, much better on all fronts.
2) I don't have any gripes with the stock camera app so I can't really help on that one. You could try the stock Google Camera, which is a pretty decent camera app on my Nexus 7.
3) Phone size is a personal preference thing.  I personally love the larger size of the G3 but that's just me.
2500k | Z68-UD3H-B3 | GTX 570 Classified + Accelero Xtreme III | MX 200 250GB + Seagate 500GB | R4 | Seasonic 660W Plattinum | 8GB G Skill | Acer K272HUL + 2 x Dell P2417H, Rosewill dual mount, HP 22bw | Mackie CR3, ATH-M50X | DAS Keyboard | Mobile: X1 Carbon, Nexus 6P, LG G3, Samsung S5, Nexus 7 (2013)
https://linustechtips.com/topic/394175-android-advice/#findComment-5318875
Google Messenger or Hangouts. I use the stock app on my G4 and haven't had complaints.
I would suggest sticking with the stock camera app since I find it better than the Google Camera from my personal experience.
Yes, the G3 is a big phone (I have one as well along with my daily driver G4) but you'll get used to it. It's about the same size as the Galaxy S6 overall.
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
https://linustechtips.com/topic/394175-android-advice/#findComment-5318953
