I have a Hp pavillion dv6 1334 with a intel core duo t6600 running at 2.20GHz
Its running windows 10 preview and I wanna know if I can down clock it or if I can replace the fan or the heat pipe with a different laptop cooling system. I am a full day user because high school is over and I have summer school next week and I need a laptop that can try to stay quiet than the laptop fan is on idle
I'm not thinking of buying another laptop yet....
Im thinking of putting double back thermal tape on the graphic card (with a mini fan directly connected to the usb closes to the fan) ram and some other places.
Dose anyone know if theirs a cd rom fan thingy
https://linustechtips.com/topic/394130-laptop-cooling/
So you're trying to tell us, that you want a laptop that runs with no fans on at idle? At you want to mod one into the CD drive?
PC Interest - Thriving | Wallet Status - Near Empty
Ryzen 9 5900X, ASUS TUF RTX 4080
Corsair Vengeance LPX (2 x 16GB) 3600MHz, ROG Crosshair VIII Dark Hero
https://linustechtips.com/topic/394130-laptop-cooling/#findComment-5318330
Have you seen the linus video of watercooling a macbook....
maybe you should try your luck
MOBO- MSI z97 gaming 5  CPU- I5 4690k   GPU- G1 Gaming gtx970  RAM- 16gb Corsair Vegeance  PSU- Corsair RM650  COOLING- Corsair H110iGT
STORAGE- AMD r7 120gb SSD / 500gb HDD  CASE- Phanteks Enthoo Luxe   Sound-  Logitech z506 / Corsair Void  Peripherals- G710, G502
https://linustechtips.com/topic/394130-laptop-cooling/#findComment-5318383
