I was just wondering for all of you that own it, how loud is it? There's a trick to the Realtek HD Audio Manager where you can apparently make the microphone significantly louder that can be seen here, I'd like to know if it is still acceptably loud after the following steps are done.
https://linustechtips.com/topic/39402-zm-mic1-volume/
It was acceptably loud upping the gain in windows's sound manager (friends said +20 was do-able, +30 was better), dunnae about the realtek manager.
https://linustechtips.com/topic/39402-zm-mic1-volume/#findComment-511605
And this is why Realtek is shit.
Install Gentoo GNU/Linux | "You have been placed on moderator queue. This means that all content you submit will need to be approved by a moderator before it will be shown." | top LEL
Build specs: Corsair 540, i7 2600K @ 4.2Ghz, Asrock z77 extreme4, 16gb DDR3 @1866, 2 x 1TB, GTX 560 ti
Monitors: Asus VG236H, Dell U2713HM Headphones: Koss PortaPro, DT 770 80ohm, AT-AD700 | Steam profile
https://linustechtips.com/topic/39402-zm-mic1-volume/#findComment-511669
